1 - 7 of 7 Posts
Hello
I have a tiny question:is it possible to put the head from 1,9 HO to my 91` 1,9lx? Will I get more power?
Beaverboy said:
What about all the water jacket issues I keep hearing from folks?
I'm so confused over this head swap thing.. :x
Thats if you try to swap a 1.9 HO intake manifold on a second gen 1.9.
All the 1.6, 1.9 and 2.0 CVH's share the same head gasket.
pballer98c said:
so ALL first gen gt's share the same head? so if i took an 88egt i could swap the head onto a 95 lx? thanks.
I can tell you what has been done, you can use a first gen 1.9 lx bottom end in a first gen gt with a Gt head. That lower compresstion. Good for FI.
as far as I know all CVH pretty much share the same block, just differnt pistons and heads, but the head gaskets are the same.
A SPI swap with a header will give you just as much power as a first gen GT but with out the hassel of trying to make the electronics/ignition work, the SPI has bigger intake valves anyways.
1 - 7 of 7 Posts
