Head compatibility | Ford Escort Owners Association (FEOA)
Head compatibility
Discussion in '2nd Gen 1991-1996 1.9L SOHC' started by Rocket, Dec 26, 2012.
  1. Rocket
    Rocket FEOA Member
    78
    156
    Hello all. I'm looking for a list of compatible years that I can pull parts from for my 1994 head. At a minimum I need rocker arm bolts....at a maximum I need a new head.
    I'm going to start with rocker arm bolts and work up from there. Thanks!
  2. madmatt2024
    madmatt2024 FEOA Member
    9,830
    398
    383
    Upstate N.Y.
    91-96 Escorts and Tracers with the 1.9 will work for sure. Some stuff like rocker arm bolts, camshaft, lifters, ect can also be sourced from 97-02 Escort and Tracer sedans and wagons with the 2.0 SPI should also work.
  3. white-lightning
    white-lightning FEOA Member
    2,896
    186
    Salem, VA
    Early (91-92?) heads have a different timing belt, but that can be fixed by swapping cam gears.
