1 - 5 of 5 Posts
I have jead off '92 1.9, I was hoping someone could tell me how to torque head bolts and also adjust valve rockers? I had head mill4ed and they said check the rockers. Hope someone can help, I can't find manual locally.
'92 1.9L head bolt install
First of all, you MUST use new head bolts.
-apply light coat of engine oil to the threads of the head bolts
-tighten in sequence (*) to 44 ft/lbs (60 Nm)
-loosen head bolts appx two turns and torque AGAIN to 44 ft/lbs (60 Nm)
-after 2nd torquing, turn the head bolts an additional 90 degrees
-after additional 90 degree turn, turn ANOTHER 90 degrees (that's 180 degrees from 44 ft/lb mark, but it must be done in steps)
(*)sequence...
9 3 1 5 7
o o o o o
head bolts
o o o o o
8 6 2 4 10
1 - 5 of 5 Posts
