1 - 6 of 6 Posts
You gotta pull off the rear paneling on the inside of the hatch. I think you have to pull the weather stripping on the window first, then work your way down. Then you'll get to a plastic barrier. Take that off. And the rest is pretty self-explanatory.
Could I assume you are asking because your key no longer works in the lock? I've had that problem for almost a year now (also 94 Escort) and only go in and out of the trunk through the back seat.
Yes, I know I'm asking for serious trouble should I ever need the spare. I keep meaning to get a new lock assembly one of these days...
1 - 6 of 6 Posts
