1 - 6 of 6 Posts
I found a cheap 1.8L to put in my 91 pony but I dont know if I should buy it because the connections that arent there and the expensive modifications that might need to be made.
What are they? :?:
any sensors you need should come with the motor, and I already stated the ECU. You'd need some new motor mounts, a way to route the exhaust, not sure how the 1.9 engine bay is laid out, but you might have to move/relocate the battery to the 1.8 position...
Hell I think you should stick with the 1.9 since it's already the lightest of all the 2G Escorts out there...just play with the 1.9 or drop in a 2.0. But since you have your heart set on the 1.8 good luck.
1 - 6 of 6 Posts
