Had some leftover metallic red paint and clearcoat... | Ford Escort Owners Association (FEOA)
Discussion in 'Interior Modifications' started by ArmyofOne, Aug 25, 2013.
  1. ArmyofOne
    ArmyofOne FEOA Member
    119
    29
    38
    So I took the liberty of freshening up the escort's interior today. Started with the shift knob. Rather than tape off and cut out each individual number/letter and the pattern with an x-acto blade, I simply painted the numbers and wiped away the paint from the knob while wet, leaving the paint inside the recessed numbers:
    [​IMG]
    [​IMG]
    [​IMG]
    over the next week or so, the leftover paint will rub off.
    Onward!
    Next I did the gauge cluster. all the black was driving me nuts, and since this spiffy red matches the whatever red color is on the outside of the car, I decided it was all win from there. So I took out the green signal overlays:
    [​IMG]
    and painted the cluster:
    [​IMG]
    [​IMG]
    [​IMG]
    then I took out the vents from the black dash surround, and the vents from the side of the dash (Defrost for the door windows),and the radio/HVAC surrounds.
    [​IMG]
    [​IMG]
    [​IMG]
    and this was the end result. only took about 3 hours start to finish:
    [​IMG]
    [​IMG]
    [​IMG]
  2. 4cylinder
    4cylinder FEOA Member
    696
    126
    193
    san diego, ca
    this looks better than I thought it was going to look. The only thing I would mention that you should have done would be to mask off the trip odometer push button as the paint may rub/scrape off when using it
  3. Intuit
    Intuit FEOA Member
    7,545
    924
    Southwest Ohio
  4. ArmyofOne
    119
    29
    38
    meh, that paint is not the worst thing my skin has touched. I will be ok.
    Thanks for the comments guys!
  5. BOSS302man
    BOSS302man FEOA Donator
    2,665
    44
    198
    Lebanon, PA
    Ok, what ARE you sticking your fingers into????
  6. ArmyofOne
    119
    29
    38
    I have 36 months of time in combat (Iraq 15 months, Iraq again 9 months and then Afghanistan for 12 months). Use your imagination LOL.
  7. Intuit
    Intuit FEOA Member
    7,545
    924
    Southwest Ohio
    Well, we initially shipped ya'll over there with no body/vehicle armor I guess it's no surprise we'd "stiff" ya'll on some gloves. Hope ya'll at least had some TP. Wow, welcome back. Hope the basic 'scort wasn't chosen out of financial necessity.
  8. ArmyofOne
    119
    29
    38
    No, I drive this too:
    [​IMG]
    The 'scort is easy on gas around the base. The Ram tows my Bayliner.
  9. PColumbus
    PColumbus FEOA Member
    45
    108
    I've been thinking of doing something similar to my Tracer. How easy/difficult was it to remove parts of the dash?
  10. LariRudi
    LariRudi FEOA Donator
    2,341
    219
    313
    What year is your Tracer? Gen 2 is easy. Drop the steering column by removing four bolt underneath the column; [may have to remove plastic shroud that surrounds the ignition switch and the column to access those bolts]. Then loosen 3 or 4 screws underneath that larger piece, and 2 or 3 on top side above speedo etc....
    After it's "loose", tug mostly on left side; pull it out gently until you can reach the mirror controls connector [Ford nicely made THIS piece of wire long enough to make this part manageable]. Now you can swing it out far enough to reach the rear defroster controls' connector................ remove it, presto.
    I don't know about the radio/heater controls panel, nor the AC/Heater vents.
    [Edit; PS, my experience is with a 1993 Escort LX SW 1.9]
    LarryR
  11. PColumbus
    45
    108
    Mine is 1 98 (3rd Gen)
  12. LariRudi
    2,341
    219
    313
    Might be similar, but I've heard/read that Instrument Cluster removal is EASIER on Gen 3. And if I remember right, the EASIER part is that you don't have to drop the steering column?
    Hoping I'm not mis-leading you.
    LarryR
  13. Gamer92
    Gamer92 FEOA Donator
    3,446
    987
    263
    Southern Indiana
    Gen 3 is pretty easy. The steering wheel does not need to be dropped. The cluster can be removed within 30 mins.
