1 - 4 of 4 Posts
If the GTX motor will fit with no problems, does that also go for the trans as well. Are the gears in the trans any different (smaller/bigger)because at 120 mph the tach is at 6200rpm and after I do the motor swap to the GTX I would like to have more top end speed and not be limited by the stock escort trans with no overdrive.
1 - 4 of 4 Posts
