1 - 13 of 13 Posts
I've heard that the gtx intake manifold bolts right up to the stock GT head and gives a 15-20hp improvement. Is this true? if so where can i get one?
is it the same deal for the GTR intake manifold?
thanks
DAve
91 EGT
I think it does match up, but I'm not sure about the HP's. I think to be effective, you'd have to follow through w/good exhaust system. Also, you'd have to have sufficient air coming in the engine. You can't have one w/out the other. Maybe upgrade your air intake system as well. IMO.
The GTX intake manifold is more restrictive than the stock GT one so I wouldn't swap it. The GT head is also better than the GTX head. Kinda odd that the better engine has more restrictive parts on it.
were talking intake manifold not header :)
it depends on if you use the stock ECU or the GTX/GTR ECU. If you use the stock ECU with piggy backs, then stick with the stock manifold and VICS, if running a GTX/GTR or any aftermarket ECU, use the GTX/GTR manifold.
1 - 13 of 13 Posts
