How should I wire these up witthout using a toggle? Would a fuse, maybe 30amp inline, and wiring it to the red wire of my front parking lamps be sufficent? So when my parkin lamps are on they are as well...
I would use any switch wanted, could get one for a GT(you have a spot for it) and run it's power out to a signal wire to a relay. Direct wiring the bulbs to a switch is a bad idea as 55 watts for each bulb will go through switch. Google search lighting relay diagram for clear routing.
Is there a factory plug on my pony for those factory gt fogs?
I do have the entire harness for em with pigtail.. where would this be located if it exhists?
Unsure if pigtail exists, but it would be behind the blank next to the dimmer switch... Factory GT fog light switch location.
Related Threads
FEOA Forums
834.1K posts
18K members
Since 2002
