Grinding noises in right front | Ford Escort Owners Association (FEOA)
Discussion in 'Wheels/Tires/Brakes' started by GracesDad, Apr 5, 2008.
  1. GracesDad
    GracesDad Guest
    51
    The other day the right front wheel started to make grinding noises. They would go away. I thought that it might have been from the rain we got around here.
    It's gotten worse. What can it be, after only a few days? Brakes, seized caliper, hub, any suggestions before I go to a mechanic?
    Larry
  2. therieldeal
    therieldeal FEOA Member
    8,622
    19
    338
    Northeast CT
    probably a wheel bearing or a problem with your brakes.
    ive seen the friction material delaminate from the steel backing plate on a brake pad... and then its just metal on metal grinding.
  3. masm60
    masm60 Guest
    15
    Squeal
    You might just need new brake pads.
  4. longneck313
    longneck313 FEOA Member
    150
    268
    Flat rock,mi
    grinding
    your caliper could be sticking........one day it will freeze solid
  5. zzyzzx
    15,244
    1,238
    Are you sure it's not just the rust coming off the rotor when you brake for the first couple of times?
  6. TexasTracer
    TexasTracer FEOA Member
    4,694
    17
    188
    Sunnyvale, Texas
    Check your pads and see how worn they are.
  7. celery952
    celery952 FEOA Member
    1,985
    286
    Villa Ridge, MO
    is it a rotational noise? it could also be a cv joint
    when braking it can get just the right bind on it to grind if its bad
