1 - 3 of 3 Posts
just as hard as it would be to set it up in a honda, acura, dodge, chevy, toyota... there are many that are just hand held basically that dont have an interaction with your car itself but come with brackets to mount.
Heh, that depends on how fancy you want it. Are you talking like an in car navigation system like seen on a lot of newer model cars? Or do you just want something that tells you your position on a little map? There are devices that can be handheld that show you your location, and there are devices you can plug into an in-car computer that you can interface with a touch screen and, if the software supports it, will tell you where you need to go. Be a bit more specific :)
And in true post hijacking form...
Anyone familiar with the "location" feature in most current cell phones? That E911 service that transmits your position when you call 911, or can optionally be turned on permanently. I was wondering if it was possible to get your Lat/Lon from that constantly or does it only transmit that when you make a call?
1 - 3 of 3 Posts
