i got a lot done today, i want your 2 cents to see if this will work
i attached that ground deal to the metal frame of this fuse center
i ran another pair of 10 guage wires to the terminal so its as many as there were stock
i also repainted the valve cover it should hold over the winter, in the spring il poweder coat it
i also found another caliper washer and it doesnt leak any more.
i also installed a new drain plug
