1 - 17 of 17 Posts
FINALLY got a chance to tinker on the 1st gen the other day. Took out all the A/C crap - lines, condenser, everything. Also decided to try and take out my P/S pump while I was at it.
While I was taking it out, I had the idea to leave some length of my return and pressure lines attached to the rack, route them together, and see what happens. Anyone ever done this?
I love it! The car drives great! Its not like a P/S system without the pump running - which makes the wheel pretty difficult to turn. It's actually more like a manual rack setup. Requires a little effort at a standstill, but once you're moving at all, it's cake. Anyone ever had experience with this?
89_GT said:
my ac pump is making a whining noise. can i remove the whole pump and get a shorter belt? if i can wat size of belt do i need? thanks- Arin
Yes you can. You need to get an alternator belt for a non a/c car. Just be sure to count how many ribs you have on the pulleys, 5 or 6.
Discussion Starter · #8 ·
I even used a 5 rib belt on a 6 rib pulley when swapping out my A/C because it was all I had around- and that worked fine as well. Not a long term solution, but one that works decently, I guess!
I had removed the PS pump on my supra because the rack leaked, I was basically filling it daily. Much heavier car, but I loved it! Helped work up some arm strength too. I autocrossed it like that a couple times, was a work out for sure, but I loved it.
I drove my car one day with no belt on the P/S pump and loved it. Granted I'm using a Tempo rack, so I don't know if the gearing is different (but I can check!). There are pressure seals inside the rack that cause the friction...taking the rack apart and removing these seals, then repacking with good grease will result in a high-ratio manual style rack. It's really that simple. I've seen the exploded views, and am still thinking of doing this on my car. I love the extra road feel I had, although torque steer was way more apparent.
Discussion Starter · #17 ·
I didn't even think the friction was too bad, especially with the pump and lines removed. I think I'm gonna hold off on the manual rack for a while to save some cash!
1 - 17 of 17 Posts
