I have a few questions about putting a 3rd Gen Escort ZX2 2.0 Zetec engine into a 1999 Mercury Tracer Wagon. I haven't found any info, but my Tracer Wagon has the same engine as a 1998-2002? Ford Escort 2.0 SPI which I think can have a Zetec swapped in.
My valve seat in the 4th cylinder dropped and messed up my engine. This car has sentimental value to me and I want to keep it for a long time and i wouldn't mind the extra power of a Zetec. If the engine would break down again, I would rather put another Zetec engine in it in the future, instead of the SPI's and having to buy a $300 fixed head each time.
Would the Escort zx2 Zetec engine bolt right into my car?
Can i use my current automatic transmission, or do i have to use the zx2's transmission?
If I get the Zetec engine only, does it also have to be from an automatic transmission car, or can it come from a manual transmission car?
Would this be a lot more extra work for my mechanic to swap this instead of putting in another SPI engine?
Would I need to buy lots of extra parts like new water pump, intake manifold, and all that stuff?
Would this be a huge pain in the ass without a donor car?
What kind of problems might my mechanic run into?
Since their aren't any guides, can anyone tell me exactly what modifications need to be made? I keep reading different things.
Any help would be appreciated. Ask me any questions... Thanks.
I haven't done it but plan too so I've done a little research on this.
That being said here is what I've come up with so far:
Yes but "bolt right into my car" is a bit murky. It would be best to have a donor car for all the little brackets and such that you'll need that your car may not have. Not imperative but definitely helpful. Maybe find a salvage 3rd gen ZX2 that got rear ended and use it as a donor car?
Your tranny will work. I've read that there may be a bolt or two that doesn't match up but no big deal.
Manual or Automatic bolt up the same.
There will be a few things that might be different or needed but not a whole lot. Again, donor car would be the way to go. Then your mechanic can pull whatever he needs. The rest you sell to a scrap yard to get back the money you invested in the parts car.
If yours are bad.....yes. My suggestion would be for you to take your mechanic to a junkyard and have him check the engine to make sure it's good. This way he can pull the ENTIRE engine accessories and all but again.....donor car.
Not a huge PITA but a donor car is certainly helpful.
Shouldn't be that big of a deal. Nothing really out of the ordinary for him.
There aren't really any "modifications" that need to be done.
Someone may chime in but from what I know it's not all that much work as long as the Zetec comes out of an Escort ZX2 and not a Focus Zetec.
John
