Gear ratio | Page 2 | Ford Escort Owners Association (FEOA)
Gear ratio
Discussion in '2nd Gen 1991-1996 1.9L SOHC' started by Jdeshler, Jan 23, 2016.
  1. twisted95
    twisted95 FEOA Donator
    537
    30
    178
    charleston
    oh yeah i had my eye on the klze sway. butt i to deep in the cvh to back out
  2. twisted95
    537
    30
    178
    charleston
    was this with the 1.9-2.0 or mazda motor
  3. therieldeal
    therieldeal FEOA Member
    8,622
    19
    338
    Northeast CT
    I have the 1.8 mazda engine but depending what you're trying to build there is a combo that will work, like i described above.
  4. twisted95
    537
    30
    178
    charleston
    I was going to attempt the toytoa e153 on the cvh
  5. therieldeal
    8,622
    19
    338
    Northeast CT
    You would need to have someone make you a one-off adapter plate then. To do that will be very, very expensive (i.e., you can probably buy a nice clean EGT for less). Trust me, I've been there.
    I'm having a batch of the BP x E153 plates made as we speak, if you're interested. The price for the plates will be $350ish.
  6. twisted95
    537
    30
    178
    charleston
    soon as i get. chance find the e153 trans having it in shop see what i working with i know i going to need a adapter plate
  7. Itchigo
    Itchigo FEOA Member
    361
    108
    193
    So what's top end on a 95 LX with a 1.9 and automatic? I always wanted to know. Fastest I've had mine is 105mph, and that's only because I ran out of space. (Stock, well maintained, 150k on it).
  8. Bindre12
    Bindre12 FEOA Member
    116
    38
    178
    Idaho
    the top speed of the 2nd gen is ~110mph which is electronically governed
  9. Intuit
    Intuit FEOA Member
    7,470
    881
    313
    Southwest Ohio
    I've been well beyond the 120mph max speedometer. If any are governed at all, they're not all governed.
  10. Bindre12
    116
    38
    178
    Idaho
    I have hit mine, maybe auto are different but it's like the car gives up and the RPMs cap
    Sent from my Nexus 5 using Tapatalk
  11. Itchigo
    Itchigo FEOA Member
    361
    108
    193
    Thanks to both, that's what I figured. I knew I had more RPMS left...
  12. Intuit
    Intuit FEOA Member
    7,470
    881
    313
    Southwest Ohio
    ~110 MPH registers ~3500 RPM
  13. Itchigo
    Itchigo FEOA Member
    361
    108
    193
    You mean 5500 RPM. That's about what I was at at 105mph.
  14. Intuit
    Intuit FEOA Member
    7,470
    881
    313
    Southwest Ohio
    I meant what I said.
  15. Itchigo
    Itchigo FEOA Member
    361
    108
    193
    I wouldn't have believed it if I didn't see a pic of a speedo at 110mph and 3500 browsing the site. Sorry about that. Maybe it's because I have an automatic?
  16. Intuit
    Intuit FEOA Member
    7,470
    881
    313
    Southwest Ohio
    I don't know but sounds reasonable.
