1 - 4 of 4 Posts
Did you take the needle off? If so, you may have pushed it back on too hard when you put the needle back on.
NOTE TO ALL: If you are planning on doing this (replace your guage faces) and you plan on removing the needles, make sure the engine is cool, and make a sketch, take a picture, or mark where the needles were BEFORE you removed them, otherwise, chances are your guages will be innacurate.
1 - 4 of 4 Posts
