can i simply swap in a GT or even a later LX cluster into my car? i know the dimensions are the same, but will the wiring harnesses match and will the tachometer work??
No need to swap whole cluster. Just swap speedometer and tach. Tach is just a pop up thing. Speedo is litte bit complex. But still really simple to do. If you don´t have tach originally. No need to bother installing stock GT. Just get autogage tach. Still if you want to put stock gt tach in you´ll need to run some cables from EDIS module to the dash. Still simple to do.
1 - 2 of 2 Posts
