For Sale - *G.I* Modified stock gauges & Misc lighting | Page 2 | Ford Escort Owners Association (FEOA)
For Sale *G.I* Modified stock gauges & Misc lighting
Discussion in 'Canada Classifieds' started by Silex, Dec 6, 2009.
  1. LOWETGT
    LOWETGT FEOA Member
    5,229
    24
    238
    N. Illinios
    I tried this, but with unsatisfied results. The HVAC face was a little more blue, but it was more dark and hard to read than anything. I left it alone because it is still better than the green.
    [​IMG]
  2. racethisescort89
    racethisescort89 New Member
    2,391
    In your closet watching you secks!
    you can actually remove the backings and there able to sand but UBER carefully im gonna attempt it again. i tried it on my lx and it was a super fail. i messed up sanding the letters then eventually sanded the black off between the letters:( so i had to throw it out
  3. Silex
    Silex New Member
    863
    Brampton , ON
    not everything is that simple. the paint used MUST be transparent and a rattle can is WAY to much , this is why i use a very fine air brush an gradually build up the color , i dont even have to mask anything if im doing multiple colors
  4. faizy
    faizy FEOA Member
    241
    116
    Brampton, Canada
    im interested.. i am in brampton and trying to find glow/reverse glow for 3rd gen spi se model, all i find in ebay is zx2 and mph with tech (i need without rpm).
    if u still do them, or have something i can look at, that will be great.. next week I will be replacing audio system and front speakers, and would be a good time to replace the old boring gauge too..
  5. racethisescort89
    2,391
    heyy me and silex are in brampton too im DIXIE QUEEN area. he still does em. if you pm me i can give u my MSN and we can chat more efficiently there
  6. Silex
    Silex New Member
    863
    Brampton , ON
    yea i sill do them , i'm also working on some plug an play LED back lights for the gauges , my prototype set worked well i just need to find a supplier close by to buy them from cheap enough to make it worth while.
    what colors did you have in mind?
  7. agrowagon
    agrowagon FEOA Member
    605
    266
    Okeechobee, Florida
    yo silex check out oznium.com if you haven't already they got led's for like mad cheap.
  8. LOWETGT
    LOWETGT FEOA Member
    5,229
    24
    238
    N. Illinios
  9. faizy
    faizy FEOA Member
    241
    116
    Brampton, Canada
    on ebay i came across two general types.
    1. http://imgs.inkfrog.com/pix/l3racing/RIG-269.jpg (exact match for my 3rd gen SPI without rpm)
    and
    2. http://i252.photobucket.com/albums/hh36 ... 0BLUE1.jpg (not a match, but for referencing styling/colors)
    #2 only reason i like is because the speeds like 60,80,100,120 (km/hr) are interchanging blues/reds and its visually appealing ..
    (both styles come with overlays, switch, wires, and hooking up instructions) but i cant find one for WITHOUT rpm, IN km's in outer dial
    (mods: im not sure about posting links or outside pics, let me know if its against board policy)
  10. racethisescort89
    2,391
    u can post outside pix and links man dont worry lol everyone is slack here
  11. faizy
    faizy FEOA Member
    241
    116
    Brampton, Canada
    Re: *G.I* Modified stock gauges
    this style will work perfect ...
    let me rephrase, this will work PERFECT!
    lets exchange info.. i've already met dave and good for the word on money.. let me know if this will be a standalone inverter and key on off switch or i will need to yank out cluster and replace 194 bulbs? (i have 10 white and 10 blue led's on order)
    (can't remember for what project)
  12. Silex
    Silex New Member
    863
    Brampton , ON
    that is a 3rd gen speedo in the pic , its just a simple re coloring process , no wiring , no inverters. the cluster does need to be removed an disassembled for this process though.
    i also can make the LED retrofit to brighten up the gauges alot more.
    ( if you can get the LED 194's its easier )
    if more people are interested i'll pick up some cores and have some ready to go.
  13. racethisescort89
    2,391
    i am BUUT im 2nd gen and jobless:(
  14. faizy
    faizy FEOA Member
    241
    116
    Brampton, Canada
    yup, i am a third gen, and bored with "green" stock gauge and yellow needles. led retrofit or complete replacement, i dont mind
  15. racethisescort89
    2,391
    the needles are a BITCH buut once u paint the gauges they actually do it alot of justice i wanna get white needles to match my Blue custom Gauges Silex did.
    [​IMG]
  16. Silex
    Silex New Member
    863
    Brampton , ON
    you just need the retrofit dave? or complete set
    im going to try an pick up some cores this weekend so there is very little down time on the car.
  17. faizy
    faizy FEOA Member
    241
    116
    Brampton, Canada
    ok since im the NEW kid, whats retro and whats set?
    set i am guessing u replace all lights from the back and retro would be putting up a "face" with a 12v inverter and on/off switch?
  18. Silex
    Silex New Member
    863
    Brampton , ON
    not quite
    The retrofit LED's i have done are modified 194 caps ( the black piece the bulb sits in ) they turn on , off like normal.
    depending where you get the 194 peanut LED's , my retro fit set is less $$
  19. faizy
    faizy FEOA Member
    241
    116
    Brampton, Canada
    well,
    this sounds good.. if existing setup can be used without extra wires or switches.. i will be more interested in that.. let me know what times suite u and will go from there..
  20. Silex
    Silex New Member
    863
    Brampton , ON
    likely some time this weekend we can set something up
