would a bigger fuel pump, 460cc rx7 injectors and a fmu be enough fuel for a t3 setup runnig 8-10lbs of boost?
what ratio fmu should i use?
Mabey it's because I've been drinking, but how dose this apply to a EGT? Have you even turbo'd a 2nd gen GT or are you just guessing this stuff? Is this recycled bad info from some one else that dosen't know what they are say? I'm not trying to be a butt hole or anything, but almost every thing you said makes little sence, backwards or dosen't applies to a EGT.siragan said:If you're not using a rising rate fuel pressure regulator, then you're going to have to put some serious flow through the injectors, which requires aftermarket PWM-ing software. The Apex'i SAFC will do just that, and it will also allow you to upgrade the VAM (on egts) to a MAF, i.e. the 5.0L mustang MAF.
Most people will keep the stock fuel injectors maps in their ECU and use different fuel injectors, then they'll adjust fuel PRESSURE to get the right mix. The downside to rising rate fuel pressure is that you cannot adjust the fuel pressure as a function of rpm. It is a linear relationship, which is usually about 12:1 (psi).
It wasn't a bad systm at all. Very easy to install, drilling the crank pulley to install the magnets for the timming pick up is a little scarry, but once you under stand that it's not that bad. I was 1 degree off on timming when I did it and you can compnsate for that in the program. I decided to go with a haltech E6K because my needs were changing and I was looking for more options that the haltech could do over the SDS. SDS is easy to install and programming it is very easy to understand. You can tune on the fly which is a plus. I ran the SDS for a few years and only time I had a problem with it was if I accidently bumped the quick +/- 50% fuel adjustment knob or hit a button or 2 on the programmer. Another plus is you don't need a laptop to program it.gt19ho said:How did you feel about the sds? Was it a get the job done or would you use it again, if you had to to?
It was originally the EM-4D, then I spent a little extra cash and converted to the EM-4E, so it dose fuel and timming control. It comes with a hand held programmer so no laptop is needed (didn't have a laptop back then). You can tune on the fly, upside. Down side is you can save maps and swap them out. I use to print out tables and write down my setting so I could save what I have tried.siragan said:onegimp- were you using EM-4D or the EM-4E? I think that engine management sounds like a badass way to tune...
can you save all the settings that you entered and switch saved profiles on the fly?
It is not a piggy back system. It is a stand alone engine management system and it comes with all nessasary sensers. Optional sensers cost more.siragan said:It piggybacks the stock ECU, right? Do you have any loss of functionality over just the stock ECU setup (any sensors that you can't use, etc).
Also, did you need to purchase any additional sensors?
