Fuel Rail.
I was looking at something after market, I found this OBX on E bay for 120 and change.
I am building an all motor 1.8 to go canyon running against my buddies sciroccos, rabbits, corrados.
The stock fuel rail, is not up to what I am building, I.e adjustable fuel pressure reg, and aeroquip connectors, and custom fab intake mani.
I just got the block back, from the machine shop. and I just started porting and polishing, the head. I had to cut a head to pieces to find out what thicknesses were. once that's done, I'm going to CC and high polish the combustion chambers, 3 way valve grind, 32 degree cut back on the valves, flow bench and double springs.
I was looking a possible running a 3 stage dry sump set up, but that cost coin but the extra couple of ponies, and not having to worry about the engine being oil starved, in hard corners is worth it, problems it were to put it.
the badman
