1 - 4 of 4 Posts
Does anyone have a list or know where I can find a list of the type of fuel injectors that are compatable with an SPI swap into a 2nd gen.
I am looking for a car or part numbers... for example
5.0 mustang 24#
1995 turbo t-bird
Bosch P#xxxxxx
Let's get some specific information and make a sticky
I understand that. But I am looking for specific parts and part numbers so we do not have to try to figure out (every time this question comes up!) if it is high impedance or not. I want to know that if I use Bosch P# xxxx or a 24# 5.0 msutang injector that it going to work because we have already determine by everyones input that it is infact 1) high impedance and 2) will fit.
So everybody... What injectors are you using? Let get the list made.
Fuel Injector Applications
Editor's note: This information is provided by Randy (RS450). Application Year Ford number Bosch P/N Manu. Color gm/sec #/hr ohms
1.6 1983 E3EE-9F593-BA Bosch Blue 1.76 14 2.25
1.6 1984 E4EE-9F593-AA ND Blue 1.76 14 2.35
1.6 T/C 1984-85 E4EX-9F593-BA Bosch Black 3 23 2.4
1.9 1985.5-86 E6EE-9F593-AB Bosch White 2.45 19 2.25
2.3 T/C 1983 E3ZE-9F593-BA Bosch Green 3.86 30 2.4
2.3 T/C 1984 E4ZE-9F593-AA DKK Green 3.86 30 2.35
2.3 T/C 1985 E5ZE-9F593-AA DKK Brown 4.41 35 2.35
2.3 T/C 1986 E5ZE-9F593-AB DKK Brown 4.41 35 2.35
2.3 Truck 1985 E59E-9F593-AA ND Gray 1.76 14 16.2
2.3 Truck 1986 E59E-9F593-AB ND Gray 1.76 14 16.2
2.9 1986 E67C-9F593-A1B Bosch Gray 1.76 14 14.5
3.0 1986 E59E-9F593-AB ND Gray 1.76 14 16.2
3.0 1986 E67E-9F593-BB Bosch Gray 1.76 14 14.5
3.8 CFI 1984-86 E3VE-9F593-A1A 0 280 150 402 Bosch Green 4.54 37 2.25
3.8 CFI 1984-86 -9F593-A2A ND Green 4.54 37 2
5.0 CFI 1980 E0SE-9F593-AA 0 280 150 400 Bosch Blue 5.81 46 2.4
5.0 CFI 1983 E0SE-9F593-A1A 0 280 150 400 Bosch Blue 5.81 46 2.4
5.0 CFI 1983 E0SE-9F593-A2A ND Blue 5.81 46 2
5.0 CFI 1984 E0SE-9F593-A1A 0 280 150 400 Bosch Blue 5.81 46 2.25
5.0 CFI 1984 E0SE-9F593-A2A ND Blue 5.81 46 2
5.0 HO CFI 1984-85 E4ZE-9F593-CA 0 280 150 403 Bosch Gray 6.6 52 2.25
5.0 SEFI 1986 E59E-9F593-AB ND Gray 1.76 14 16.2
5.0 SEFI 1986 E67E-9F593-BB Bosch Gray 1.76 14 14.5
5.0 HO SEFI 1986 E6TE-9F593-AB ND Gold 2.45 19 16.2
5.0 Truck 1985 E5TE-9F593-AA Bosch Gold 2.45 19 15.5
5.0 Truck 1985 E5TE-9F593-AA ND Gold 2.45 19 16.2
5.0 Truck 1985 E5TE-9F593-AA DKK Gold 2.45 19 16.2
5.0 Truck 1986 E5TE-9F593-AB DKK Gold 2.45 19 16.2
5.0 Truck 1986 E5TE-9F593-BB Bosch Gold 2.45 19 14.5
2.3 HSC 1985-86 E43E-9F593-AC Bosch Blue 7 56 1.4
2.3 HO HSC* 1985 E53E-9F593-AB Bosch Green 8 64 1.4
2.3 HSC 1986 E53E-9F593-AB Bosch Green 8 64 1.4
Note: The entire Ford part number will not appear on the injector. For example a E4ZE-9F593-CA will only have E4ZE-CA
These injectors should be modified to hold the EFI o-rings. RC Engineering can do this modification, or you can take a look at this picture to see what needs to be done.
http://www.turboford.org/faq/injectors.shtml
This is from turboford.....read that board some they have alot of good info over there.
1 - 4 of 4 Posts
