Fuel - Fuel Hose, tank to filler neck, how long should it last... | Page 2 | Ford Escort Owners Association (FEOA)
Fuel Fuel Hose, tank to filler neck, how long should it last...
Discussion in '2nd Gen 1991-1996 1.9L SOHC' started by axa, Jun 27, 2017.
  1. Maxwelhse
    Maxwelhse FEOA Member
    783
    181
    103
    There's no doubt your approach gets it done, but I get older, fatter, and lazier with each passing minute and I like easy stuff that just bolts on to the things I'm not trying to hotrod. I've got enough projects that require a creative mind.
    I don't golf so the last time I thought I broke my shaft was when I slipped off the only woman goodly enough to tolerate me.
  2. Itchigo
    Itchigo FEOA Member
    374
    117
    193
    Me too, me too. That golf club was less than 10 years ago. You should see me now lol.
    I can't shut my creative mind off lol. And alcohol makes it worse in my case.
  3. axa
    axa FEOA Member
    265
    48
    178
    So this damn tube is on its way to failing again. might make it another year but shouldnt.
    Last time i just found a seller off of ebay, figured how much worse could it be... and turns out just as bad...
    bought this:
    Motorcraft KFL22 Fuel Hose
    from these guys:
    https://www.ebay.com/usr/original_auto_parts_xpress
    on this date:
    ORDER DATE
    Jun 28, 2017
    So amazon bad, ebay bad, that might come as no surprise but i figured they all used the same vendors... ill try rock auto for rubber from now on.
  4. denisond3
    10,043
    2,774
    I dont think you will have much better luck from other sources. Rockauto has to buy from whatever market they can find.
    I replaced one in my 92LX about 9 or 10 years ago; getting the KFL-22 branded as motorcraft. It hasnt leaked yet, though I havent looked at it to see how it is going. When I put a new one on a 95LX for my daughter, I smeared Permatex ultra black RTV on the outside of it. This would at least keep most of the air and UV away from the hose. I will do the same, when I change the OEM hose on my 91LX. It is leaking, along with the smaller hose that allows the vapor bubble to escape as I am filling the tank.
  5. Itchigo
    Itchigo FEOA Member
    374
    117
    193
    Straight hose from NAPA is fine. It's not like there are any funky bends or anything.
    Marvin likes this.
  6. axa
    axa FEOA Member
    265
    48
    178
    i think this becomes the only path
  7. axa
    axa FEOA Member
    265
    48
    178
    Would you, or anyone know the size host i need to get a good fit?? id like to pick one up before getting the old off, if possible....
  8. Joey_Twowagons
    Joey_Twowagons FEOA Member
    2,379
    1,095
    Vancouver Island, Canada
    It was either 1-7/8" or 2" inside diameter.
  9. denisond3
    10,043
    2,774
    Measure the diameter of either of the tank inlet, or the fuel filler metal tube. Then use the smaller diameter, not the enlarged part right at the end. I find it works better to expand the hose by jamming it over the end of a small-to-medium laundry detergent bottle.
  10. zzyzzx
    15,033
    1,179
    This is what happens when all you can buy are new old stock parts.
    austin86 likes this.
  11. Joey_Twowagons
    2,379
    1,095
    Hey, I found this picture from when I changed mine:
    Marvin, axa and zzyzzx like this.
  12. axa
    axa FEOA Member
    265
    48
    178
    could not imagine a more precise answer to such an obscure question tossed out on the internet. thanks.
  13. Marvin
    Marvin FEOA Member
    53
    47
    28
    I still have original on mine. But if/when it does fail I plan on using marine grade hose that they use on the tanks of boats. Fuel grade hose is available by the foot at many hydraulic specialty companies if you don't live near marine stores. Same kind of hose is also used on heavy industrial and farm equipment. You can get them in silicone, have multiple layers and are reinforced with a wire core. You may need a heat gun to form it and it's probably an over kill solution.
  14. zzyzzx
    15,033
    1,179
    I like overkill.
  15. austin86
    762
    248
    58
    Ohio
    over kill is even better on a escort.
  16. axa
    axa FEOA Member
    265
    48
    178
    Speaking of which. I can't find any fuel house this big, granted I've only just checked advanced Auto and auto zone, but is generic fuel house in this size hard to come by?
  17. denisond3
    10,043
    2,774
    Generic fuel hose is made in a variety of sizes. The sizes I needed for my mopar motorhome and my F1 pickup were somewhere about 2-1/4" diameter. They only sold it in 3' lengths though. The big hose I got for the replacement on my escort fuel filler neck-to-tank was a KFL-22 made by motorcraft, Its still pretty common, and could be found on ebay, or I imagine at lots of truck parts places.
    I think of advanced auto and autozone as good places to buy antifreeze, motor oil, and sponges for cleaning a car; not so much for real auto parts. I visit a local NAPA franchise sometimes, and O'Reillys. I also go to independents, which arent one of a chain of the places that sell more chrome muffler extensions than they do obscure auto parts. They can be tough to find though.
    If you are replacing the cracked and leaking fuel filler neck hose, also think about replacing the smaller fuel "vapor" hose next to it. I forget whether I used a 9/16" or 1/2" size of heater hose. While it dosent say it is for gasoline vapors, it sure has worked well for several years.
    I have gone into places where huge trucks were being worked on, and asked the guys in dirty coveralls where they get their parts. The always know the names of dependable parts outlets, and they never say advance auto or autozone.
  18. axa
    axa FEOA Member
    265
    48
    178
    Just got back from a specialty Auto parts store, as you said seems these fuel house in these sizes only come in 3' lengths, around 35$ where I am.
    The reason I don't use the kfl22 is that I'm convinced availability is highly infiltrated by fakes, thus the reason I started this thread having 2 fail quick, one from eBay, one from Amazon.
  19. denisond3
    10,043
    2,774
    I have had better luck with them; having done three now, one of them about 12 years ago. With my daughters 96 escort sedan last summer, I smeared the outside of the fuel filler hose with Permatex RTV, 'Ultra Black'just to keep the fumes from the engine compartment off of the hose.
  20. zzyzzx
    15,033
    1,179
    Not fakes, just new old stock that is mostly aged out.
