1 - 6 of 6 Posts
I'm sure I have read a thread on this before, but....
What should one do when your fuel gauge needle sticks? The needle will start sticking in between 1/2 to 1/4 tank,of course until the morning you're headed to work and you look down and your driving on "E"!!
Any one else have this problem? Gracias!
The problem is either with the sending unit of the fuel pump or the gauge in the cluster itself. When you begin to empty your gas tank, there is a linkage up to a variable resistor in the sending unit. If your sending unit is fuxxord or the gauge is screwed up, you'll get a screwey reading.
i dunno, i would just keep on driving it as-is, just having to use the trip odometer after filling up everytime until it annoyed me enough i would get it repaired. which would be about a week, so i say listen to siragan. :lol:
1 - 6 of 6 Posts
