I swapped my gauges... 93 LX... for gauges out of 92 LX sport... now all gauges work except fuel gauge and it reads E all the time... gauge worked in other car as it read 3/4 when i pulled it.... i am confused
Did you have the same cluster in your car or did you do a swap so you get the tach?If you did the swap there is some wires that are crossed I believe.Thats why you gas gauge isnt working.
Someone here wrote a diagram for the wiring of it but your best bet is to get the wiring diagram from ford for your 93 and the 92 cluster so you know where to relocate the wires.
Yeah the wires in the 3 plugs differ in their location on the plug from year to year. I had a similar problem. There may be some idiot lights not working too that you haven't noticed. I had to open my door and let the belt retract BEFORE I pulled the parking brake on, or they wouldn't retract!
I've never swapped gauges before, but if you have your cluster off, with the key in the "on" position and a volt or multi meter, you should be able to find the correct wires if you know you have fuel in the tank.
