Checking interest.
1993 Mazda 626 ES automatic, 215,000km (not miles)
Light grey leather interior with only mild cracking on the left part of the drivers seat. 9/10
Body is in excellent shape, only MILD LIGHT surface spots on the right rear wheel well. Undersize is spotless! Paint is faded on the right left 1/4 panel tho.
EVERYTHING WORKS! Even the motorized vents that move left to right!
LIST OF PARTS REPLACED (new or under 5,000k)
2 o2 sensors
cap/rotor/ngk plugs/8mm kingsborne ignition wires
Front & rear valve cover gaskets
Master cylinder/calipers/rotors/pads/rear brake lines
KYB struts/mounts/boots/bump stops with Votland springs
Front & rear strut bars
Blacked out headlights with all new bulbs
Intake manifold was recently cleaned along with the intake ports
2.5" flex pipe-back exhaust with Magnaflow cat/res/chambered muffler
15,000k EGR valve
I'm probably missing lots still, I'm only trying to get $2,500 e-tested, or $2,000 as is. Safety was done less than 3 months ago and only needs front tires (toe issue after i lowered it, has proper alignment now)
Trades are welcome/considered.
Here's some pre-lowered pictures, car is now 2" lower.
Located in London, Ontario.
2 o2 sensors
15,000k EGR valve
