1 - 15 of 15 Posts
my windshield and driver side window completely frost up on the inside!??
any ideas how ican prevent this or get rid of it without spending 10min scraping every last inch of it off
it takes a good 10min for my defrost to get rid of it
HOW DID THE WATER GET IN THERE:(
that's happened to me once or twice. i scraped it.
try putting some Rain-X or something on the inside of your windows. might help
Welcome to living in a cold climate.
This is normal. Unless you stop breathing, or it stops being damp outside, you will never get rid of this.
Matt 8)
the last time that case happened to me its when I get my shower and 5 mins after the showeer , I went to the job at -14 celsius
I just drove like jim carey in Ace Ventura ;)
BE CAREFUL WHEN DOING THIS!!!!
place a small space heater in yoru trunk on a piece of plywood wiht your trunk carpet out. crack your front windows about and inch. flip down your rear seats (hatchback or trunk). crank that thing up and let it sit for a few hours or the day. it will dry you out good! if that doesn't solve the issue then look into all your seals and start teh problem solving.
NEUMAN
I get this EVERYDAY in my winter beater (89 Micra) and it is due to the fact that it has no weather stripping on the back window so it's ure weather stripping on one of ure windows! I have gotten used to the fact that scraping it is the answer since I am driving my micra off a cliff when spring comes!! :twisted:
marclar said:
the trunk usualy has water in it, leakage arround windows, and weather striping.
Or water coming into the outside air for the heater intake when there is a clog in the drain in the fender (where the runoff from your windshield goes to).
1 - 15 of 15 Posts
