front sway bar? | Ford Escort Owners Association (FEOA)
front sway bar?
Discussion in 'Autocross & Road Racing' started by rangestang, Jun 20, 2011.
  1. rangestang
    rangestang FEOA Member
    427
    26
    Anyone ever remove the front swaybar or loosen the front endlinks to reduce plowing for auto-x?[/list]
  2. jay92gt
    jay92gt FEOA Member
    725
    24
    268
    Bristol CT
    left foot brake and increase your rear tire pressure.
  3. rangestang
    427
    26
    So you think its a bad idea? Have you tried it and didn't like it or what?
  4. jay92gt
    jay92gt FEOA Member
    725
    24
    268
    Bristol CT
    disconnecting it would bump you out of stock and would cause a lot of body roll and snap oversteer which can be hard to handle.
  5. rangestang
    427
    26
    Polyurethane bushings bump me out of stock class? I know I'm being lazy and not looking it up for myself.
  6. Auto-X-ZX2SR
    Auto-X-ZX2SR FEOA Member
    48
    158
    In SCCA stock class, FSBs are free. That means that any bar and any non-metallic bushings may be used.
  7. rangestang
    427
    26
  8. GregF422
    GregF422 FEOA Member
    3,224
    7
    288
    Seattle, WA
    I run in ST class (SCCA Central Florida Region). As far as tire pressure i typically run ~45-50 psi up front, ~40-45 psi in the rear.
    I've had my front swaybar endlinks disconnected for a few seasons now. It does make the car body roll quite a bit. and it is quite prone to snap overstear. It can be especially touchy if you've got the springs loaded up and hit a large seam or a rut.
    However, it does feel like it grips in the corners much better. With the endlinks attached it felt like the initial turn-in grip was all the grip there was and it would just understeer through the turns. With the endlinks disconnected it feels like it actually grips through the turns. It's quite predictable most of the time, but it takes a little getting used to when you get out near the ragged edge.
  9. rangestang
    427
    26
    Thanks for all the input, would there be any advantages to running a larger front sway bar on the street for a 2nd gen wagon?
