I have just finished installing all new bushings for the front end suspension on both sides. To my surprise, I NOW have a sound coming from the front left tire area. I did not have this sound before I replaced everything. To describe the sound the best I can, it sounds like an "underwater" knock or pop when I shift the suspension around. I especially hear it when I accelerate every so slightly in the forward direction from a completely stopped position. I can also feel it at my feet when I drive.
New lower control arm bushings
Outer tie rods
Lower ball joints
Sway bar end links (not the inner sway bar bushings)
The only thing I think it could be are the end link bushings. The noise sounds like to me one of the end link bushings has popped off or something. However, after inspecting everything down there, everything seems to be perfectly in tacked. My second guess would be is a bolt is not tight. But, I made sure every bolt was very tight before I lowered the car.
Any help would be greatly appreciated. Thanks!
Outer tie rods
Lower ball joints
