Two studs on my front left wheel snapped and im currently running on two lugs. I was wondering if it was possible to remove the hub and put a new one on or if I should buy spacers that I saw on ebay. If anyone has an opinion please post, thank you?
Exactly im not in mood to remove the hub so i'll take a look at it tomorrow if erika let me, to see if i am able to remove the lug and install the other with ease and with out removing the hub.madmatt2024 said:Drum, so this is on the back I take it. On the back the hub and bearings are one assembly that can be removed without a press. I think there is a reasonable amount of room back there as well so you may not even have to remove it.
