Wthin the last 3 or so months, my GT has developed a "growling" noise in the front passenger side. It sounds like a bearing is going out, but both wheel bearings are good and both axles are less than 1 year old. The noise is only there while accelerating in first or second gear after ~2500 rpm and will get louder as the rpm's go up. I can feel it in the steering wheel as well. I'm guessing it is the carrier bearing on the pass. axle causing this.
This noise started before I put in the ES motor mount inserts. After the inserts it seems a little louder, but it is not getting any worse. The tranny is full and has been switched to gear oil.
Has anyone ever had this bearing go bad? If so, where did you find a replacement? Or could it be a bearing in the tranny going out?
Thanks for any and all help.
