Ford zx2 2000 no spark reverse battery | Page 2 | Ford Escort Owners Association (FEOA)
Discussion in 'ZX2 1998-2004 2.0L DOHC' started by Andy_dre38, Mar 23, 2017.
  1. Andy_dre38
    Andy_dre38 FEOA Member
    16
    yes it comes on
  2. Andy_dre38
    16
    i still cant fix it my i had someone test the electric current it goes to coil pack but as soon as it cranks there is no power to it
  3. pextor
    pextor Moderator Staff Member
    5,932
    791
    Lancaster, pa
    please list everything you have replaced.
  4. Andy_dre38
    16
    i replaced the ecu and pcm
  5. Andy_dre38
    16
    and the 100a fuse it gave power to the car but it did not spark
  6. madmatt2024
    madmatt2024 FEOA Member
    9,849
    410
    383
    Upstate N.Y.
    Those both refer to same thing.
  7. Gamer92
    Gamer92 FEOA Donator
    3,445
    987
    263
    Southern Indiana
    Has coil been checked or replaced?
    Has crank sensor been checked?
  8. pextor
    5,932
    791
    Lancaster, pa
    What year is your car?
    what is the code/part # of the replacement computer that you put in the car?
    Did you replace the module under the airbox?
  9. Andy_dre38
    16
    yes and the code is perfect match as old one
  10. Andy_dre38
    16
    yes coil has power when tested but then it cuts off
  11. marclar
    8,918
    519
    seabeck WA
    cam sensor is a sensor. it has no power running thru it. coil doesnt care about the battery, its just an output. you fried the protection diodes in your modules when you hooked up the battery wrong.
    without doing some major testing, your going to have to start replacing modules, and again check all the fuses inside and out
  12. madmatt2024
    9,849
    410
    383
    Upstate N.Y.
    Um, most sensors do have power running through them, usually a 5V reference. There also aren't many modules in these cars. The only ones I'm aware of are the ECU which does the engine and transmission, a fuel pump driver module, an airbag module, and the CCRM which is hardly a module at all. On top of that these aren't CAN bus vehicles that need everything working or it won't run. OP has replaced both the ECU and CCRM which covers every module that should have to do with spark. He needs to pull codes and look at live data on a decent scan tool.
  13. madmatt2024
    9,849
    410
    383
    Upstate N.Y.
    Just looked up a wiring diagram. Coil circuit has one 12V power wire that is hot when the key is in the "run" or "start" positions and two wires that the ECU grounds when it wants to fire the coil. If that wire doesn't have power when cranking then it could very well be related to the ignition switch. Since the coil has power when you are in the "run" position try to 'pop start' the car or manually trigger the starter solenoid. I bet it will start.
    bent_rod likes this.
  14. marclar
    8,918
    519
    seabeck WA
    i apologize, i will be more specific in the future. i was refering specifically to the VR sensors. but you are correct. most inputs do have a 5 volt ref which is controlled by the pcm and is regulated via a linear voltage regulator. but this is very easily tested.
    OP needs to verify power to the coil like your saying in crank positon.
  15. Andy_dre38
    16
    OK there is power to the coil when i checked with a probe tester and power cuts out when it is in crank position so does that mean it is just a wire?
  16. madmatt2024
    9,849
    410
    383
    Upstate N.Y.
    It means the ignition switch is most likely faulty.
  17. marclar
    8,918
    519
    seabeck WA
    put an ignition switch in it.
