1 - 3 of 3 Posts
Im having problems with the almost new foglights I bought. I've had them for 1 year and now all of a suden they stoped working. I tought the lights were dead but i looked at them and they seem ok. I tested to see if there was any power going to the lights and no power.
I know the fog lights use the same fuse that the normal lights use so it can't be the fuse...
Any ideas?
you probally already did this. Your gonna want to check ALL your connections. Make sure they are still clean, the corrosion could have done something. And sometimes, very rare but it could be that the fogs are tapped into something else. Doubt it, wouldnt hurt to check. other then that im all out of ideas.
I did check the connectors and i did find corrosion but this is why I tested to see if power was coming out before the connectors.
Thanks for your input, you gave me a idea. There is a connector coming from the headlight and going down I will check that one... Thanks!
1 - 3 of 3 Posts
