1 - 12 of 12 Posts
Sure it will
Even though it's for the Focus it's
A nice upgrade from the stock manifold with no mods
Required to put it on your
Car, my
Homey.
coyote-x said:
Sure it will
Car, my
Homey.
ok i take that as severe sarcasim!! so ya it will fit?
Yes, yes it will fit. It's a direct bolt on, all you need is new gaskets. You don't even need to get your exhaust redone or the cat relocated or anything.
Mentioned many times before. Heh.
Discussion Starter · #8 ·
i dont plan on keeping my cat on my car i will be getting a high-flow cat and a spring coupler so my exaust can flex
It's only a Direct bolt on for third gens Escorts, 1.9's use a different cat flange all together, and EGR is in a different spot to.
But the SPI shorty can be used on a 1.9 with a little work, or a third gen down pipe/cat.
justinescort22 said:
this might seem like a stupid question, but...logic tells me that if the focus header fits, then the focus cat-back should too...
Nope the floor pan of a focus is not the same.
No the floorpan/chassis of a focus is not the same so the focus exhaust will not fit an escort.
1 - 12 of 12 Posts
