1 - 5 of 5 Posts
ok i just realized that i have 2 bp motors on the side of my house. i was planning on getting my stock setup all together and throwing it on in one day
gtx mechanical setup... injectors, turbo, manifold and dp...
gtx ecu
walbro fuel pump
gtx sidemount ic (waiting on a donor unsure if it will go through or not)
i was kinda gettin worried about the oil and water lines but moron me i can go and bolt it all up to one of my spair motors then 1 run the lines and 2 work on a fmic setup while i wait for the final parts to come in.
i had one fmic question... i noticed that the charge pipe directly off the turbo will be hella tight... so what way do you fmic guys route the pipes... do you go down then to the passangers then through the core support.... yadda yadda yadda or what?
thanks for any help in advance
thanks guys... i think i got the picture. im at my cousins house right now so ill go and look at the turbo when i get home to understand where that pipe is going... obviously its going to the passangers side but... yeah... anyway nice pipes neuman... well nice ride period :)
*PM sent to neuspeedescort*
1 - 5 of 5 Posts
