So I'm in the middle of a clutch rebuild and I'm wondering if anyone knows the factory recommended step height for the flywheel. This would be the distance between the friction surface that the clutch rubs on to the surface that the pressure plate assembly bolts to.
The machine shop that I'm going to have resurface the flywheel said that they're just going to take the same amount off of the friction surface as they'll take off of the mounting surface but is there a specification of how far apart they need to be or does the clutch even wear the flywheel enough to affect this distance?
