Flushed the cooling system
297 Views 8 Replies 5 Participants Last post by  Mark Eric Roth
This stuff STUNK, smelled like rotten fish. Flushed it about 6 times and got it to be clear.
Paint Gas Plastic Wood Bottle
Water Dishware Serveware Rectangle Grass
See less See more
  • Like
Reactions: 2
1 - 9 of 9 Posts
did you use any additives, ?
yeah i used some super flush additive on the first and second flush. the rest was just distilled water.
Obligatory:
this is exactly what i followed! my picture doesn’t have the last flush but it was pretty much clear. this cooling system has NEVER been flushed. i’m sure the previous owner was just running water in it so it was filthy.
Did you find the fish?
yeah, a big 7 pounder swam out of the thermostat housing
  • Like
Reactions: 1
I got a medium, mouse sized lump of brown slime out of the engine when I flushed out the '92 Protege in the fleet.
I had tried flushing the heater core to fix a low output fault, then thought of doing the engine as well, through the heater core connections. This worked much better than flushing the engine the usual way.
1 - 9 of 9 Posts
