Floorpan pic | Ford Escort Owners Association (FEOA)
Floorpan pic
Discussion in 'Escort Wagons' started by novanutcase, Mar 1, 2020.
  1. novanutcase
    novanutcase FEOA Member
    2,669
    639
    263
    In case anyone was curious what the floorpan looks like without the carpet. I'm currently replacing the carpet. Unfortunately I also found out my clutch slave master is leaking so before I install the new carpet I need to replace the clutch slave master.
    [​IMG]
    Also, ZX2 seat belts won't fit in the wagon. They mount differently and won't seat correctly. Since I'm trying to do a color change I wanted the belts and accompanying hardware to also be black and these are the closest to black I was able to get with standard OEM equipment. I may try and remove the belt cartridges and install them in the original wagon assemblies but I'm pretty busy so time is limited in regards to taking on a project like this.
    John
  2. Joey_Twowagons
    Joey_Twowagons FEOA Member
    2,635
    1,256
    Vancouver Island, Canada
    Neat! Is that a third generation? The fuel pump access cover looks a bit different from my second generation, but it could be the angle of the photo.
  3. 1993tracer
    1993tracer FEOA Member
    216
    31
    278
    Are you doing any soundproofing too? I had my carpet out last year, but didn't add any additional soundproofing. I think most of the engine noise is coming through the firewall and windshield anway. The 2nd gens had a hood blanket, which the 3rd gens don't....probably accounting for the added noise of the 3rd gen. When I pull my dash, I will be doing all I can to cut down the noise. I plan to do the hood too.
  4. Itchigo
    Itchigo FEOA Member
    383
    121
    193
    That fuel pump cover is different from the 2nd gen, you are correct.
    I did this to mine, but I'm not sure how effective it was. I also have a hole in my rocker too, which accounts for some noise.
  5. novanutcase
    2,669
    639
    263
    Yes, 3rd gen. From Itchigo's photo the cover does look a little different although actual access looks pretty much the same.
    Yes. Sometime ago when I bought the carpet kit I also bought some soundproofing material so I'll be taking advantage and covering the floor and firewall with it. I may use some of the old pad in the footwell for some extra soundproofing since a lot of the engine noise comes through the firewall as you mentioned.
    John
  6. Itchigo
    Itchigo FEOA Member
    383
    121
    193
    Access is the same but don't forget the 3rd gens have metal tanks, not plastic.
    Uncovered pic.
  7. novanutcase
    2,669
    639
    263
    Really? I could've sworn when I replaced the fuel pump the tank was plastic.
    John
  8. Itchigo
    Itchigo FEOA Member
    383
    121
    193
  9. madmatt2024
    madmatt2024 FEOA Member
    9,929
    439
    383
    Upstate N.Y.
    97's have plastic tanks, 98-03 have metal tanks. Fuel pump, EVAP system, lines, and and filler neck are also different between those years.
  10. novanutcase
    2,669
    639
    263
    I must have one of the early '98's because mine has a plastic tank.
    John
  11. madmatt2024
    9,929
    439
    383
    Upstate N.Y.
    The switch supposedly occurred when they switched to the return-less style fuel system, which was the 98 model year. If you ended up with a 98 that has the return line style fuel system or a plastic tank with the return-less system then that's really odd.
