1 - 11 of 11 Posts
What's the point? Does the trunk remain level thoughout its swinging travel?
I personally like the linkages used in the stock jetta/golfs. The trunk lid is actually a two bar linkage system, so it doesn't sweep out the area that a normal trunk lid with a single pivot would. The result is a trunk lid that can open in a much smaller area. I personally think that that would be a much cooler mod. No offense, just being practical.
In more funny terms... I think that a "suicide" trunk lid would be rice-a-riffic. Why would you want a trunk lid that opens toward the person? Instead, put the pivot point at the bottom, by the license plate. It would be the coolest thing evar.
flip trunk
The mod cost a pricey $5 :lol: The trunk operates just like normal for every day use right now but can flip down for shows. I am looking at ways to improve on it. I would like to work out a motorized lift system but I also want to keep it simple. It really is so simple of a mod that it is laughable that some places charge $200 for the kit. I wouldnt want my trunk to flip like that all the time as it makes it harder to access the trunk but once I get a new sub and amp setup in the trunk it will look cool. At least I think so and that is what really matters :D
suicide trunk
If someone does a suicide trunk where it opens the wrong way they should mount a BBQ to it so it has some use. :twisted:
I think it looks pretty good! and ur right.. if you think it does, that's all that matters!
HA! I did that mod to my car...same price. The only problem I had was that it did not stay level when it was flipped down. It would swing down and the latch would rest on my window. I got two pieces of chain and made them support it, but mine is a crappy job, but it works. The seams also dont match up anymore.
Discussion Starter · #11 ·
flip side
did you put a spacer in there along with the hinge? That is the same hinge I have. I let the area where the lower bolt goes to sit a little loose so that the trunk gasket does the alignment for me.
1 - 11 of 11 Posts
