So, gas tank leaks. Did a few searches, but didn't find anything that really helped me, all threads with pics had broken links, and I'm a very visual person. Is the part in question here?
If someone can point out the part to me I'll make a how-to to be moved into the correct forum as this seems to be a common problem, and the pics will last as long as my photobucket acct does!
You can see some of the damage does to the rubber type material to the right, and it's also started soaking into the seat foam. I found a receipt under it from what looks to be from a shop that replaced the seat bottom, I'll take a pic as it looks a lot better than the one I found in the LX I used to have.
