First time clutch replacement | Ford Escort Owners Association (FEOA)
Discussion in 'ZX2 1998-2004 2.0L DOHC' started by ThatOneDude, Sep 1, 2019.
  1. ThatOneDude
    ThatOneDude New Member
    Just got the car recently its a 1999 zx2 been having a hell of a time, made some mistakes need some help got the car on a lift engine amd transmission have jacks supporting them transmission is unbolted but I never in did the drive shafts because they are stuck ive tried prying and hammering and pulling and can't get them off was wondering if there is a way to replace a clutch with out removing axles
  2. ShakeZilla19
    ShakeZilla19 My name is ^^^
    3,150
    650
    263
    I had similar problems taking the transmission out. I ended up getting a 5lb slide hammer with a claw attachment.
    [​IMG]
    I suppose you could take just the engine out but i've never tried it and that might be impossible.
  3. 4cylinder
    4cylinder FEOA Member
    670
    122
    193
    san diego, ca
    the passenger side for zx2 has half shaft and simply unbolts then slides out
    the driver side is the side held in with clip on axle. if you cannot get this out then you can just remove the axle from the hub and remove trans with axle attached
