firewall | Ford Escort Owners Association (FEOA)
firewall
Discussion in 'ICE (In Car Entertainment)' started by dusty122, Feb 20, 2013.
  1. dusty122
    dusty122 FEOA Member
    18
    hey, im gonna hook up my amp soon but how do i run the cables through the firewall is there a whole i can use already with a rubber gaumet or do i need to make a hole and is it hard to do. can someone of you explain your story???!?!
  2. denisond3
    10,043
    2,774
    The 3rd gen. Escorts may be different than the 2nd gen, but on mine there is a hole for the 'cruise control' cable. Its covered by a rubber plug, and located close to the 10:00 position of the vacuum brake booster. With the rubber lid off, that is where I put wires through.
  3. ShakeZilla19
    ShakeZilla19 My name is ^^^
    3,167
    663
    363
    I ran my power wire through the fender into the door. If your wire is bigger then like 6ga this wont work. I wanna say Redse did the same thing. I can post pics if you like.
  4. neuspeedescort
    8,125
    98
    348
    wenatchee, wa
  5. dusty122
    18
  6. neuspeedescort
    8,125
    98
    348
    wenatchee, wa
    a single 4ga would fine for that amp. the reason i did the two run on that customers car was he had a 4 channel the size of yoru sub amp and a 2K for his sub.
  7. dusty122
    18
    ok im planning on mounting my amp on the back of the rear seats what length cables should i get? cuz they come in diff lengths. it would just save me the trouble of getting a rough estimate.
  8. neuspeedescort
    8,125
    98
    348
    wenatchee, wa
    15' would be best for your rca's
