http://www.harborfreight.com/cpi/ctaf/d ... mber=98793
Fender Repair Tool
Use for fender collision repair or fender flaring, or to increase fender clearance.
Fits most cars and light trucks with 4 and 5 lugs
Simple and easy to use
Roller works on fender from inside wheel well
Attached hitch pin allows for wide or narrow angle
Adjustment arm has second telescoping arm with roller that allows for 180º wheel swivel
Base mounting plate dimensions: 3/8" thick x 5-7/8" diameter, center hole: 2-3/4" diameter, 8 mounting holes: 9/16" x 1" long; Support bracket: 5/16" thick x 6-1/2" long; Adjustment arm: 2" square tube x 6-1/2" long; Second arm: 1-1/2" square tube x 9" long; Overall length: 27" long
ITEM 98793-1VGA
$79.99
