Facts and Figures | Ford Escort Owners Association (FEOA)
Facts and Figures
Discussion in '2nd Gen 1991-1996 1.8L DOHC' started by James92Scort, Sep 13, 2004.
Thread Status:
Not open for further replies.
  1. James92Scort
    James92Scort Guest
    8,915
    5
    Basic Technical Specifications
    Engine Built by: Mazda
    Engine Code: BP-ZE
    Engine Size: 1.8L (1839 cc or 112 cu in.)
    Type: Inline
    Base Cylinders: Four
    Equipped with VICS, Variable Inertia Charge System. See pictures Below.
    OBD: I (OBDII came on 95.6-96 models)
    Valvetrain: DOHC, 16V
    Redline: 7000 RPM *fuel cut out at 7200 rpm*
    Compression Ratio: 9.0:1
    Bore x Stroke (mm): 83x85
    Internals: Forged steel
    Block: Iron
    Piston Designation: BP05 (stamped on underside)
    ConRod Designation: S7 (stamped on side of rods)
    Drivetrain: Front wheel drive (FWD)
    Chassis Code: CT-20
    Transmission Type: 4 speed Automatic or 5 Speed Manual
    Transmission Model: (5 speed only) 1991-1992: G5M-R 1993-1997: G25M-R
    Gear Ratios: (I am unsure if they changed in 93 when the model changed)
    1st: 3.30
    2nd: 1.83
    3rd: 1.31
    4th: 1.03
    5th: 0.79
    Final Ratio: 4.10
    Peak Horsepower: 127 hp @ 6500
    Peak Torque: 114 lb ft @ 4500
    Suspension, Brakes and Wheels:
    Macpherson Strut style
    Front and rear disc brakes
    1991: 15" Aluminum Alloy "fanblade" style GT wheels [Note: Caymen Green GT's had painted fanblades to match Green color.]
    1992: 15" Aluminum Alloy "fanblade" style GT wheels
    1993-1994: 15" Aluminum Alloy "fanblade" style GT wheels with non-painted fanblades, no center hubcaps
    1995-1996: 7 spoke symmetrical 15" rims hubcaps, non painted
    Dimensions:
    Exterior
    Length: 170 in.
    Width: 66.7 in.
    Height: 52.5 in.
    Wheel Base: 98.4 in.
    Curb Weight: 2458 lbs. (GT models)
    Interior:
    Front Head Room: 38.4 in.
    Front Hip Room: 51.3 in.
    Front Shoulder Room: 53 in.
    Rear Head Room: 37.6 in.
    Rear Shoulder Room: 52.6 in.
    Rear Hip Room: 46.6 in.
    Front Leg Room: 41.7 in.
    Rear Leg Room: 34.6 in.
    Luggage Capacity: 17.3 cu. ft.
    Maximum Seating: 5
    Exterior Features:
    ~~It's a two door coupe hatchback called a "Notchback" because the trunk area is covered from view from outside the car
    ~~The GT Bumper with Integrated fog lamps and a 7 slant special GT Grille
    ~~A special three piece non-functional spoiler which only resides on the 1991 and 1992 Escort GTs
    Factory Features:
    ~~An AM/FM tuner & tape player Speakers: Front: 5 1/2" Rear: 6x9
    ~~Four Way Power Mirrors
    ~~Rear Defogger
    ~~Automatic shoulder seatbelts
    ~~GT Bucket seats w/ 6 way manual adjustability
    ~~Power Steering
    ~~Tilt Steering
    ~~Cruise Control
    ~~ABS & Airbags weren't standard until the 94 model year
    ~~Power Locks, Power Windows optional on 94-96 model year
    Variable Inerta Charge System Pictures:
    VICS Idle-4500 rpm closed butterfly valves;
    [​IMG]
    VICS 4500-7000 rpm opened butterfly valves;
    [​IMG]
    Vacuum Canister controller:
    [​IMG]
  2. 91sleeper
    91sleeper Moderator
    1,675
    288
    Western WA Nudist Colony
    Most 91 Gt's have the unpainted blades. Only the "Caymen" edition GT's had the color-matched wheels.
  3. James92Scort
    James92Scort Guest
    8,915
    5
    Yeah I been trying to figure this one out myself... i wrote that and lately been seeing otherwise...
  4. Black93GT
    Black93GT Guest
    185
    The 93 GT has the five spoke wheels without hubs. The 94 - 96
    had the 7 spoke wheels with hubs. In 93, the pink/ purple color
    called Iris, had the same colored wheels as the car, and they were
    the 91- 92 GT rims with hubs. :)
  5. James92Scort
    James92Scort Guest
    8,915
    5
    Thanks guys I'll update it all after work.
  6. MadBrad
    MadBrad BYO Plastic cutlery
    9,866
    11
    338
    Pickering, Ontario
    the 93 and whatever other year had the same wheels were nonpainted DIRECTIONAL. The earlier painted ones were not directional. I've seen 94 iris cars with the older style painted with cover non directional wheels too. It is odd.
    95.6? that's funny.
    I don't know but I thought ABS was optional once it came around.
    the speakers are 6.5 and 5X7
    the 94 had a driver airbag, so no automatic shoulder belts, but the 95 and 96 had dual airbags, which is why it has a Tracer dashboard.
    for 94, the bodyside moulding moved into the groove in the sheetmetal and thickened.
    for 93, the side cladding was dropped in favour of a rocker extension and as you said the spoiler went to a one piece model that was shared with lesser Escorts that had an appearance package.
    for 93, the lights all changed. The refractor pattern on the headlights(actually im not sure about the headlights) and front corners went from 3 to 5 horizontal rows, The type of side lamp went from 1157 to 2357. the taillights and the amber reflector bar got a new refractor pattern as well as the bulb type change.
    for 93, the upholstery and door trim were improved, and again for 95.
    I think another feature is all GTs had map lights.
  7. Black93GT
    Black93GT Guest
    185
    The 94 - 96 still has the automatic shoulder belts.. Abs was optional
    when it came out in 94 - 96. The 94 - 96 GT also had power windows
    and door locks optional. The 94 GT was the first year to get a optional
    factory am/fm stereo with compact CD player. 8)
  8. MadBrad
    9,866
    11
    338
    Pickering, Ontario
    OK I guess just in Canada they did it.
  9. birddog
    birddog Guest
    709
    nope, the 94 gts have auto shoulder belts. I should know I have one.
  10. thescortgt
    thescortgt New Member
    822
    Michigan
    yep, my 94 gt has em, and it has the 7 spoke non painted rims, single driver's side airbag but no abs sadly.... just 4-wheel discs
  11. Caymen
    Caymen FEOA Member
    410
    266
    I have a '96 EGT. Power Windows, Power Locks, Dual Airbags, Automatic belts. No ABS.
    Tom
  12. mikeflys1
    mikeflys1 FEOA Member
    520
    266
    New Milford, CT
    Actually its MECS, Mazda Engine Control System. VICS is just the system for the dual runner intake.
  13. James92Scort
    James92Scort Guest
    8,915
    5
    I used engine management system for a lack of better term....
  14. SportScort93T
    SportScort93T New Member
    165
    Denver
    oh, and a notchback is not a hatchback...
    Notchback=trunk, like the LX-E and tracer LTS
    Hatchback=GT and all the 2 door escorts, has a hatch.
  15. pLx
    pLx New Member
    328
    louisville kentucky
    actually, a hatch back is like a golf or civic hatch, our escorts are notchbacks, by having that little lip at the base of the window where the spoiler sits makes it a notch back, a mix between a hatch and trunk, the lx-e and lts had trunks not notchbacks, ford never made a true hatchback escort
  16. SportScort93T
    165
    Denver
  17. SportScort93T
    165
    Denver
    ok...what i want to know is, has anyone taken the time to measure the valve sizes, rod length, rod and main bearing sizes, etc.? if i had an engine to tear apart i would do it, but no garage=no spare engine for the time being.
  18. James92Scort
    James92Scort Guest
    8,915
    5
    buy my engine, rods, block, head and you can do all that. I don't feel like pulling everything out from it's hiding spot.
  19. James92Scort
    James92Scort Guest
    8,915
    5
    Trunks are enclosed spaces. Like you'd find on normal coupe/sedan Escorts. Notchbacks are hatchbacks with a covering over the non-enclosed trunk space. Only way to get into your trunk is through the trunk lid or, if equipped, through the backseats. A notchback just has a covering, but is still not enclosed from the cabin space. A hatchback is just an open trunk space and is completely accessible without removing anything from the trunk space.
    hatchbacks are like Civic hatches or a Geo Metro.
  20. sleeper7
    sleeper7 New Member
    495
    Ontario, Canada
    Heres some information about the automatic version, you may want to add.
    The auto tranny is a type "F" 4eat . It is used in escort, tracer, and capri and 323. Similar to the 4eat used in probes and 626's. There are some major differences however.
    The type F 4eat is used with both 1.8 and 1.9l engines.
    It has a 120 lb-ft torque capacity.
    The Stall speed for 1.9L is 2400-2700rpm
    The Stall speed for 1.8L is 2200-2500rpm
    Gear ratios for 1.8L:
    Torque converter stall torque ratio = 2.100:1
    1st = 2.800
    2nd = 1.540
    3rd = 1.000
    OD = 0.700
    Reverse = 2.333
    Final gear ratio = 3.736
    ATF Type = Mercon or Dexron II
    ATF Capacity = 6.3L / 6.7 US qt. / 5.5 Imp qt.
    I also have specifications of drumspeed to vehicle speed at various tps voltages. As well as specific line pressures for each gear. I dont know how much detail to go into so I didnt post them but I will if anyone wants them. I have this information for both 1.8l and 1.9l engines, I only posted 1.8l because this is the egt section.
Thread Status:
