I am located in the Orangeville, Ontario area (close to HWY 10 and hwy 9) ALL PRICES ARE OR REASONABLE OFFER. I have for sale the following items from a 1999 Ford Escort ZX2 with 2.0L Zetec engine with automatic transmission. The car and engine had a total of 162,055km's on it when the motor died and I scrapped the car. 1. Rebuilt(@ Eagle Transmission in Scarborough,Ontario) Automatic Transmission with just under 10,000km's on it. Paid over $1500.00 Code F-4EAT have the warranty certificate. I have almost New from FORD Metal Transmission Cooler Lines I also have the FORD Starter and Passenger Drive Axle. All the above items for $550 Or Reasonable Offer Below are the pictures: 2. Almost New Radiator with built in transmission cooler, for vehicles with A/C, attached to this is also the Original working fan assembly. I also have New Upper and Middle Radiator Hoses, an OEM Gates Thermostat with o-ring, Radiator Cap and a used (less then 10,000km's) Metal Heater Core Coolant line. All the above items for $130 Or Reasonable Offer Below are the pictures: 3. Seats are gone. 4. 4 x Almost New MotorCraft Spark Plugs (under 1000km's on them, need to be cleaned a little as there is die-electric grease and anti-sieze on them)These were purchased directly from the FORD dealer at a cost of over $40.00. I'm asking $25 Or Reasonable Offer 5. 1 x Used FORD Horn $5.00 ORO 6. 1 x Almost New Serpentine Belt Tensioner(under 5000km's on it) The Orgianal one broke, This is a replacement GoodYear Unit which I paid $110 for, I'm asking $75 Or Reasonable Offer 7. 1 x Almost New Power Steering High Pressure 'J' Line off the power Steering Pump(Only 158Km's on it), it will come with a new White Nylon Washer from Ford, I paid $100, I'm asking $70 Or Reasonable Offer 8. 1 x Used 2.0L Zetec Spark Plug Power Coil with 4x Spark Plug Wires $60 Or Reasonable Offer 9. 1 x Used Maf with Complete Housing and Intake Tube, including the Air Temp Sensor $50 Or Reasonable Offer 10. 1 x Used(Rebuilt) Constant Control Relay Module ( CCRM ) Fully Working Air Conditioning ( A/C ) with this unit, I have the sticker for this with the serial and codes (F8CF-12B577-AA). I have another extra working unit as well (F6SF-12B577-AA) (under 5000km's on this unit) $100/EACH Or Reasonable Offer 11. Up for sale is a working re-built ZX-2 Alternator, it has very low km's(under 1000km's) since the rebuild was done. During removal the voltage regualtor was damaged where the plug goes in, but it still works without issue. I can have this replaced for additional $, or you can swap your old one over. $80 Or Reasonable Offer Thank You for looking! Ad restored 8/21/2012 93scortluv
Restored User complied with the rules for this section and his thread has been restored! Happy selling! 93
interested in parts what is your contact number and do you still have MAF housing with sensor. Tony 416-768-8669
Hi there, I know that this is an old post but I would be interested in your rebuilt transmission if it is still available. Please, let me know. JAGR
super old, last activity was 2012.... if by some miracle these are still available i would be interested in a couple things at much better prices...
still have the transmission. maf, coil and wires , rad and fan, coolant pipes and a couple more items... i moved to orangeville and have finally gotten around to getting on here.
