1 - 12 of 12 Posts
Bee Tee Double-You, I'm just being a dick because this thread started off shitty and I don't see it getting any better. :(
You don't know if it's cracked, you didn't tell us why you think it's cracked, hell, we don't even know what kind of engine you have.
well.....could be the seal that is not quite well sealed..have you tried exhaust ciment around the joint between exhaust manifold *header* and the catalyst converter's inlet pipe?
and if its crak..remove it and try to get it welded...or get another one from the junk yard...
man..how can you crack an exhaust manifold.....did you let it run super hot and then drop it in ice lol?
1 - 12 of 12 Posts
