There must be a connection.
Here's the time line of events.
Left the car (95 LX 1.9 wagon) at the airport while on vacation. And left the lights on. Not smart, I know. Would not turn over no matter what. AAA noticed the main fuse had blown. Replaced it. Car started but the battery (4 yrs old) wouldn't hold a charge.
Got a new battery.
Suddenly I'm running hot. But the coolant is right and there are no leaks.
Then the car just up and died. On I-95 no less.
Replaced the alternator and was back in business though still running hot. The fan would not come on.
Yesterday I noticed that when I was at a stoplight the a/c compressor seemed to make the car want to go forward and the cold air would momentarily turn warm then back to cold.
Before I had a chance to attend to the running hot problem, the car started to cough and sputter as if not it was not getting enough gas.
Also, the fasten seat belt beeper sounds at random even though the seat belt is fastened. And the horn quit working.
Is there a connection between the running hot & running rough and the fuse & alternator? I am assuming the alternator is working properly but its only been a day. The belt was in top shape so I didn't change it. The common denominator seems to be that all of these problem appear to be electrical in nature. Am I right?
Several months ago I replaced the thermostat and also replaced the fuel pump. Everything was fine until the main fuse blew.
Any clues will be much appreciated. I have the Haynes manual. I just don't know where to look.
Thanks in advance.
Got a new battery.
Thanks in advance.
