I found this while searching the web for escort wheel info.
( I could not determine to what the MM measurement refers.)
http://www.vehicle-bolt-pattern.com/for ... guide.html
wheel size bolt pattern lug size MM offset *
ESCORT 81-90 13 X 5.5 4X108 12mmX1.5 63.6 H
ESCORT LX, WAGON 91-94 13 X 5.5 4X100 12mmX1.5 54.1 H
ESCORT GT 91-96 15 X 6 4X100 12mmX1.5 54.1 H
ESCORT LX 92-97 14 X 5 4X100 12mmX1.5 54.1 H
* The offset of a wheel is the distance from the mounting surface of the wheel to the true centerline of the rim. A positive offset means the mounting surface of the wheel is positioned in front of the true centerline of the rim / tire assembly. This in effect brings the tire in to the fender well more. Conversely, a negative offset means the mounting surface of the wheel is behind the true centerline of the rim / tire assembly. This will cause the tire to stick out away from the vehicle.
H = High Positive or FWD (Front Wheel Drive) typically 45,40,35 offsets
M = Medium Offset or RWD (Rear Wheel Drive) Typically +20 offset
L = Low Offset or RWD (Rear Wheel Drive) Typically 0 offset
