1 - 4 of 4 Posts
Only post once. Pick the appropriate forum and post there. 4 of your 7 posts are double posted.
Thank you...
emberglow65 said:
How much of a 94 Mazda Protege is the same as an Escort? Will the rear disc brake parking brake cables interchange? everything else looks the same.
Kevin Gross
[email protected]
With this being in the 1.9 forum, nothing is compatible. However, 90-94 Proteges are nearly identical to 91-96 GTs.
the brakes should interchange though between the escort and protoge regardless of engine
1 - 4 of 4 Posts
