Escort RS Turbo manifold, problems? | Ford Escort Owners Association (FEOA)
Discussion in 'Forced Induction & Nitrous' started by wagonbeater, Sep 13, 2007.
  1. wagonbeater
    wagonbeater New Member
    788
    so, i did a search and didn't find a complete answer.
    what are the pros and cons of the RS ant t3? what needs to be moved? changed, modded.
    PVC?
    thanks for any input.
  2. alxdgr8
    alxdgr8 New Member
    3,053
    Seattle, WA (previously Greenwood, IN)
    pvc and depending on ur t3 size, possibly the radiator..or at least the upper mounts notched to lean it forward a bit
  3. wagonbeater
    788
    i seen clutch slave cylinder? is that true? it didnt look like it was that close to everything.
  4. 1lowscort
    1lowscort FEOA Member
    3,066
    288
    Missoula, MT
    works great on a 1g :)
  5. NYinThaBuilding05
    NYinThaBuilding05 New Member
    1,171
    Poughkeepsie, NY
    the RS mani is only a good fit(least modifications) on a 1g.
    all other gens the clutch slave has to be replace, moved , or modified.
    the PCV has to be modified(a lil difficult) to work unless u have a 2000 and up block.
    i had one but sold it. too many fitment issues on my 3g.
    but it can be made to work
  6. 1Sleepy93
    1Sleepy93 New Member
    4,662
    Port Orchard, WA
    PVC needs to be moved if you have one.
    Clutch slave will need to be relocated if you go larger than a .42/.48 T3.
    Radiator will need to be moved forward a little but that's easy.
  7. Jeffescortlx
    Jeffescortlx FEOA Member
    8,421
    13
    338
    Minnesota
    Works good on the SPI Focus.
  8. wagonbeater
    788
    is a t3 42/.48 T3. a good sized turbo for my 1.9? wanting it for just my pleasure of romping around with some more power... and to run down a stock 2g N/A eclipse? :D
  9. rix415
    rix415 Guest
    282
    I got the .63 on mine and i think it sucks. You have to trick the car into making boost and it always feels like your chasing it. It really doesnt even get fully spooled. Could be my tune but i am actually switching it out to .42/.48.
    to give you an idea i start making boost between 2,500-3,000.
    lowscort has an rs setup like me but hes got the .42/.48 and hes at 15 (full) boost by 3,000 rpm.
    so when i drive i have to think - no turbo, no power, and down shift accordingly. The smaller turbo will make for a more fun ride and is a better match IMO.
