escort gt start | Ford Escort Owners Association (FEOA)
escort gt start
Discussion in '2nd Gen 1991-1996 1.8L DOHC' started by sous, Nov 14, 2008.
  1. sous
    sous FEOA Member
    37
    106
    ive got an escort gt and the car dont have the distributor ive got one of another egt and put it on my car and he dont start ive check firering order and i have fire and gas whats the problem
    thanks
  2. win0857
    win0857 FEOA Member
    1,117
    4
    288
    Connecticut
    If you have spark and fuel then check your compression. The only other thing that comes to mind is if the converter is completely plugged but I doubt it. Did you put distributor in correctly?
  3. ScortGTX
    ScortGTX FEOA Member
    112
    166
    you probably put the rotor cap in the wrong position... unlike different car the distributor rotor can be inserted in 3 diff ways.. you'll have to find which is which..
  4. sous
    sous FEOA Member
    37
    106
    i have check for put the rotor on the two other side and it dont want to go or ill try to put it today
    and the distributor cant not be put on the other side
  5. BOSS302man
    BOSS302man FEOA Donator
    2,665
    44
    198
    Lebanon, PA
    I'm sure the distributor can only be put on 1 way. But the cap is most likely your problem. That always amazed me they would have a set up like that. Most cars are one way only.
  6. sous
    sous FEOA Member
    37
    106
    ill check and i see my hose have a crack it could be the problem that the hose come to the throtle body to the air flow meter
  7. sous
    sous FEOA Member
    37
    106
    the bp still dont start i dont know were to check
  8. sous
    sous FEOA Member
    37
    106
    update the egt still dont start i was think my timming belt jump a tooth and
    [​IMG]
    [​IMG]
    i've put the crank to the t mark and the the notch on i and e on cams sprocket and it should be aligned
  9. sous
    sous FEOA Member
    37
    106
    i think my intake came are a tooth in advance
    tanks i need to know
  10. sous
    sous FEOA Member
    37
    106
  11. 88scortgt
    88scortgt FEOA Member
    750
    166
    Elkhart, IN
    It looks like it might be off, or the belt is loose and the cam moved. From the pic you posted it looks to me like it is off about 1/2 a tooth. How long has the car been sitting? As much rust is on the motor, you might want to check all the grounds and make sure they are good.
    Just out of curiosity, did you double check the rotor after you put #1 cylinder at TDC? Have you checked the compression yet? Does it even try to start?
  12. sous
    sous FEOA Member
    37
    106
    the car sit for about 2 year and the engine make fire and try to start it explode in cylinder
  13. sous
    sous FEOA Member
    37
    106
    ill check the rotor tonight if is in good position and does the crank have to be on the T mark
  14. 88scortgt
    750
    166
    Elkhart, IN
    2 years?! Did you drain the gas tank before you tried to start it? It might not want to run because the gas in it is no good. You might want to change the fuel filter as well.
    Yes, the T is for TDC. If you want to make sure it is on TDC on the compression stroke, put the plug back in, but leave it loose. Have someone bump the motor over until you hear the pressure leaking past the plug. Stop the motor as close to the point where the pressure is leaking, then move the crank by hand to line up with the marks. Check the rotor after this to make sure it is on #1 plug.
  15. sous
    sous FEOA Member
    37
    106
    ok tanks for reply ill check tonignt
  16. sous
    sous FEOA Member
    37
    106
    i have check the rotor and went the engine are at tdc the rotor are on the 1 plug wire on the cap its hard to put timming belt at the timming mark
  17. 88scortgt
    750
    166
    Elkhart, IN
    If you can't get all three of the timing marks lined up, you might want to take the belt off and reinstall it so the marks are correct. It probably wouldn't be a bad idea to replace the belt and tensioner unless you know they are fairly new.
    If you just want to see if you can get it to run, go ahead and reuse the old belt & tensioner, but plan on replacing them soon. It also wouldn't be a bad idea to change the water pump when you put the new belt on.
  18. Bomdoutscort
    Bomdoutscort FEOA Member
    1,249
    10
    288
    Cincinnati, Ohio
    how about you spray some starting fluid in the throttle body with the plate open and install the intake tube back on and try to start it. if it starts then your problem might be the gas.
  19. sous
    sous FEOA Member
    37
    106
    i have do it whit intake kleener and brake kleener
  20. Bomdoutscort
    1,249
    10
    288
    Cincinnati, Ohio
    does it start and run fine while its on there?
